I'm capturing from a terrestrial analogue ariel and capturing with my Matrox G400Tv using VirtualDub. Problem is, on one channel, I get some interference which manifests itself as a kind of rippling effect of the whole picture. The ripples are a few pixels wide and are horizontal, moving slowly in a vertical direction on the screen. I can put up with the interference at this stage, but when I try to convert it to Mpeg or DivX it looks a bit crappy.
Hope you understand what I am trying to describe. Does anyone know any virtualdub filters that might combat this problemo?
thanks![]()
Try fooling around with the Temopral Cleaner, Dynamic Noise Reduction, and Temporal Smoother filters for VDUB. Sorry, I don't have a link for these on hand.
I capture from analog cable and usually only need to use the Temporal Cleaner, so try that first with a threshhold of 50-100. If that isn't enough, try adding some dynamic noise reduction or temporal smoothing (too much will cause motion blending, so be careful) until you find a combination that suits you.
<font size=-1>[ This Message was edited by: N0SoopForU on 2001-10-24 02:27:37 ]</font> -
If converting to MPEG, the noise removal filter in TMPGEnc 2 sometimes does wonders. Alas, it slows processing to a crawl.
It actually appears to just be a smoother, but it does work.
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
possible interference?
By magmo in forum Blu-ray RippingReplies: 2Last Post: 21st Jan 2009, 03:57 -
Interference from Firewire??
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Nov 2008, 14:52 -
Material with interference problems needed
By sylvanez in forum RestorationReplies: 2Last Post: 28th Oct 2007, 14:21 -
What type of picture interference am I seeing here?
By mvdude in forum Capturing and VCRReplies: 4Last Post: 13th Jul 2007, 11:39
