Hi, i have downloaded a few svcd's, and because my dvd player doesn't player doesn't play svcds, i thought it would be best to convert the svcd to dvd and then watch the full film. However, every time i have converted from svcd to dvd, using Tmpgenc, the film seems a bit "jumpy" i.e. it doesn't run smoothly. I use Nero 6 to burn the dvd, and tmpg author, to author. I have tried burning at 2x and 4x.
I'm not really experienced when it comes to encoding, so i tend to use the wizard in Tmpgenc to kinda make the settings.
Can anyone advise how i could overcome this and what would be the ideal settings to convert from s/vcd to dvd?
thanks, any help is geatly appreciated
Are the SVCD's NTSC or PAL and are you trying to convert to NTSC or PAL?
There is the problem , different framerates . Converting correctly from NTSC to PAL is a bit complicated . I had a similar problem to yourself.
What I found is that all my dvd players including PS2 and DVDrecorder are happy to play NTSC films so instead of coverting to PAL DVD and getting picture judder I have started converting to NTSC DVD and Hey Presto no more judder.
I suggest you give that a go.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
DV vs DVD conversion
By asopher1 in forum Video ConversionReplies: 6Last Post: 11th May 2009, 12:12 -
HD DVD conversion help
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2008, 07:44 -
conversion from 2 avi files to a one DVD title in DVD flick
By netimen in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 09:06
