Hello everyone, I need a guide to convert a 25FPS DivX with AC3 audio file to NTSC VCD. Up until now, I've been using this guide:
https://www.videohelp.com/forum/viewtopic.php?t=166237
Of course, I've switched around a couple things but it has worked fine so far....
Today I tried my usual method of converting:
Open TMPGEnc. Load the AVI. Choose the NTSC Film template.
In Settings > Check "Do not frame rate convert"
Then loading the Unlock template, and hitting "System Video Only".
This would make me an MPEG with no audio...
Then I'd usually reload the AVI into TMPGEnc, choose "ES Audio Only", and it would create me a MP2 file which I would convert to 23.976 fps using BeSweet. Then I would multiplex the mpeg and converted audio file, and I'd be done.
Now I'm having a new problem, whenever I try to convert the audio using BeSweet, I get this error:
What do I do? Do you guys know of any other program that converts the fps of audio files?
Should I just load TMPGEnc, choose the NTSC Film template, and let it convert both at the same time? Thanks in advance.
Results 1 to 1 of 1
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 02:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 23rd Jan 2008, 23:13 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 12:13
