Sup guys kinda new to The dvd scene but first system specs
p4 2.6c 800mhz fsb
win xp pro sp1a
512mb ddr ram
Sony Dru-530a
dvd shrink 3.1.6
nero to burn
[general]
ok ive been using memorex 4x dvd-r and ive been able to burn them fine play them in my apex dvd player no problems. i still dont know what media code they are clueless on how to find out.
[labeling]
ive labeled a few of my backups and some of them skip and stuff really starting to piss me off. i used the neato labeling system w/ the stomper
i like the way they look w/ the labels but if there gonna skip it sucks ne ideas or suggestions, and ne good ways to take the labels off.
[maxells]
are these good blanks?? they say made in japan and are 4x i havent burned w/ them yet. i bought two ten packs from wally world(wal-mart) for 15.00 each w/ the jewel cases.
[memorex]
whats the deal w/ these bad boys??? they good bad?? whats the best kind of media to burn w/
ne way thanks for the time to read it ..
all suggestions comments
are accepted thanks guys
coop
jmhsdarren@hotmail.com
Labels are evil, never use them!!! They just make 99% of discs playback with errors.
I only use sony and tdk dvds. I hear maxel is also good. And only burn them at the speeds they are marked, if you burn them faster there is more chances of getting errors.
I dont know how to get media codes of discs either...Im kinda new too. -
This is a great site with most of the information you need available to the left of you in the sidebar menu.
There is a freeware program called dvdinfo pro. This program will tell you the media code and allow you to run diagnostics on your burner and test the burned media for error codes.
Within Nero is a program that check cd speed. In one of the pull down menus is media id code.
You can search under media to find information about various brands or by media Id to see what supplier use which vendors/discs.
Many people have many opinions on dvd blanks.
I can tell you that many members are not fond of Memorex. I have burned over 600 Memorex dvd-r 4x discs without a problem. I have burned 450+ TDK dvd-r discs without a problem.
I tried the Memorex printable discs, which have the same media code as the non-printable, and I did not have a usable burn. I used Ritek/Ridata G04 printable discs and I did not have a usable burn. In each case, the dvd burner indicated a successful burn.
The non-printable TDK discs I am currently burning are media Id as ritek G04.
I have had with mixed results with Princo discs. My success rate was/is. I no longer use, was 95%. Discs with media code AN31 and AN32, sold under a variety of names, do not work well for me.
My burners are two Pioneer dvr105, a Panasonic Lf-D521, and a Panasonic set top dvd recorder-hs2
Finding a BDXL writer AND best place to buy 50 GB media
By AARRGGHHH in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jan 2012, 12:06 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Need help finding a good media center.
By ReaperBoy2010 in forum Media Center PC / MediaCentersReplies: 4Last Post: 6th Oct 2010, 08:59 -
Any DVD or BR burners made in Japan?
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 14:38 -
Media Made in India, Thailand, China or Taiwan.
By DroWni in forum MediaReplies: 1Last Post: 16th Sep 2008, 14:45
