I want to get a dvd player this month..
It's between Sony Dvps300 or Panasonic RV31k?
hope u guys can give me some good advices..
Every review i read about are the same?!
Right now I am having some difficulties with my RV31K. IT plays DVD’s fine, it will not read the names of my MP3’s, and I created some VCDs and SVCD’s. some play fine and some are having problems with being jittry. Actually right before this topic I posted a topic about this standalone being a bitch.. you might want to keep an eye on any responses I get. The SVCD’s that are jittry on my RV31K play fine on the PC and other VCD players... Ponders the problem………….
Dont get Sony!!!! Panasonic is ok, but i recomend a pioneer they can play everything (cept MP3 on most models). They have great quality. Sony is very very picky with CDR media. Panasonic is not bad but has no SVCD
i suggest u get the panasonic RV31k becuase u can play all cdr/rw media and has alot of great function or get this apex player it is really cheap and plays ll cdr/rw meadia u can read more here
http://www.circuitcity.com/ewebIMa/detail.jsp?BV_SessionID=@@@@1589058145.1003887176@@...k_15&oid=37009 -
sony: better picture and sound quality. use princo blue cdrs or any cdrw.
apex is cheap because it's crap. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Apex may be cheap but they are multi format! My girlfreind got one (Apex 500w) and it's okay for $100. You can also change the heck out of it like the start-up screen!
<font size=-1>[ This Message was edited by: Feslmogh on 2001-10-24 10:21:01 ]</font> -
get a pioneer u get great video and audio quality and it supports pretty much everything
Get Sony
I had the same exact delima back in June. I went with the Sony DVP-NS400D. I got it at Sears for $190. It is a newer model than the Sony Dvps300 for about the same price. Right now Buy.com has it for $199. What I did was found the lowest price I could find on the Internet (using pricewatch.com and MySimon.com and other price search engines). Once I found the lowest price, I printed it out and took it to Sears. The pricematch electronics, even from the Internet. At the time, you couldn't find my model for under $250, except from the Internet. So far it has read every CDR I've thrown at it. It plays VCDs and XVCDs well. It doesn't play .MP3 or SVCD, but not many do. The picture quality and sound are incredible. I'm so happy with my purchase. I recommend the Sony DVP-NS400D.
Sony a33 or Panasonic GH1
By pjtn in forum Newbie / General discussionsReplies: 0Last Post: 18th Jun 2011, 06:47 -
Sony/Panasonic m2ts file date correction
By renzo2000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Aug 2010, 16:07 -
Going HD with Sony - but with lots of Panasonic miniDV tapes to cap
By japniz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 13th Mar 2008, 22:14 -
Which do you prefer: Panasonic dvd-s2 or Sony ns67p?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Feb 2008, 14:31 -
Sony and Panasonic miniDV tapes do not mix
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 14th Jun 2007, 12:24
