Have no one had this problem ?
DVDLab accepts the ac3 and the m2v movie file, but after I have compiled, the audio is not in sync with the video in power dvd.
How come ?
If i convert both audio and video in TMPGEnc and after authoring it dvdpower plays it well...
And yes, I have use ac3 fix and there were no bad frames...
I had this problem when I was trying out the trail version of DVD-Lab and I narrowed it down to the fact that my source was a progressive 23.976fps NTSC source that I encoded with TMPGEnc Plus using the built-in 3:2 pulldown. Apparently DVD-Lab didn't like that and I read that the work around would have been to encode at 23.976fps without pulldown then run the resulting M2V through PULLDOWN.EXEOriginally Posted by Draven
However since the same TMPGEnc Plus produced M2V and my AC-3 audio files authored with no sync problems using 2 other respected DVD authoring programs I decided NOT to register DVD-Lab and today I mostly use TMPGEnc DVD Author.
I solved my problem...
The source I had first was a avi that was "mixed" with..
It had audio that was saved out first by virtualdub as an wav(directstream), then joined to the avi again.
I tried with another source(same movie) that contained ac3 and did as I use to do ...and no sync problems...
I don't really know why I got the sync problems ... I mean it's still same ac3 file ..
Audio sync issues - H264 and AC3
By xtrattitude4u in forum Video ConversionReplies: 0Last Post: 6th Sep 2011, 02:22 -
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 21:58 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
AC3 Audio Out Of Sync In MKV
By XiATH in forum Video ConversionReplies: 1Last Post: 24th Jan 2010, 11:09 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 13:27
