Results 1 to 13 of 13
  1. Lo mates i have used DVDshrink to backup my movies But now i have had an error for the first time.
    I have tried v. 3.16 and 317b5
    But i cant get it to work Anyone know what to do?
    Never argue with idiots, they will drag you down to their level and beat you with experience
    Apr 2002
    The State of Frustration
    Play the main movie while trying to rip.
    Hello.
  3. Ok how do you mean by "play"?
  4. It does not mather if i have "enable video preview" or not if that was what you ment.. Sorry for my bad spelling..
    Apr 2002
    Nope, I meant launch DVD Shrink and your software DVD player, when the DVD menu appears, select "Play Movie".
    Now, while the movie is playing, rip the DVD with DVD Shrink.
    Hello.
  6. That did not work either... No dvd session key error.. =(
  7. I get both session-key error and CRC blablabla error... not at the same time
  8. Also tryed in DVDXcopy Did not work.
    Jul 2003
    michigan
    crc error is cyclic redudancy, which means dvdshrink cant read it, your disc is either dirty or scratched
  10. Ok so thats the problem.. Ihave tryed to Clean it but it did not work...
    So i can not back it up or what?
  11. Ís there any other program i can use that might work better?
  12. You could try ripping it with your burner, instead of your DVD-ROM drive ....... burners can be a bit more tolerant.
    Failing that .... you are stuffed !
