  1. I have been quite successfully converting avi's to mpegs to author to dvd & have always extracted the audio from the avi file as recommended in the guides to avoid any potential synch problems.
    I'm having problems saving a .Wav file using VirtualDub with certain files and am instead prompted with this message :-
    'The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format.'
    I have no idea what this means. Could someone less clueless than me please help.
    File Info from GSpot:
    Video Codec : Xvid
    Audio Code : ac3 (0x2000) Dolby Laboratories, Inc
    Apr 2002
    The State of Frustration
    Try Virtual Dub AC3.
    Hello.
  3. That did the trick.
    Thanks Tommyknocker.
