I've finally gotten to spend some time with my new ADVC-300, and find that it seems to switch itself into digital input mode during analog captures. This happens whenever there is a "rough scene transition" on the analog Hi-8 tapes I am attempting to convert. What I mean by "rough" is that recording on the tape was halted by shutting the camera off instead of pressing the record button, and/or the tape was removed to clean the heads or to record to another tape, and then reinserted.
This unsolicited toggling problem occurs in spite if my having manually selected analog mode, and reoccurs later (after manually reselecting analog) for the same apparent reasons. These unsolicited mode changes abruptly halt my captures, as there is "no output" while the ADVC apparently looks in the wrong place (DV port) for input.
Unlike the ADVC-100, the 300 does not appear to have a setting by which one can select and "force" analog capture. Is there a means by which to force/hold analog mode in the ADVC-300, or to otherwise mitigate this problem? This apparent hard-coded "auto mode-select feature" of the 300 will not work for me, as my entire tape library is unfortunately rife with these ugly transitions.
Also, I should think that if I manually select "Analog" the unit should stay that way, regardless of the content of the video. Any insight that you could provide would be greatly appreciated.
Thanks very much for your time and consideration.
Bill T.
Results 1 to 1 of 1
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
canopus ADVC-55 conversion analog to digital on MacPro
By morgankia in forum MacReplies: 3Last Post: 27th Oct 2009, 22:56 -
ADVC-300 Adjusting Image Settings - Need another ADVC?
By MitchJi in forum RestorationReplies: 0Last Post: 1st Apr 2009, 13:36 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 14:29 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
