I tried to encode a couple of quicktime .mov files to mpeg4 .avi with mp3 sound. I'm using ffmpegx 0.0.9a.
After the encoding process is complete, the created .avi file has great video qualitiy but no sound!
I tried to encode the sound seperatly, but ffmpegX says "audio codec not found" or something. When i encode a .mpg file, there's no problem with the sound.
How is it possible to encode a .mov file to a mpeg4 .avi with sound?
Results 1 to 10 of 10
Mr.Ash5Guest
Mr.Ash5Guest
Ok, i found out that encoding to a SVCD isn't a problem. Video and sound quality are quite good.
But why isn't it possible to encode the .mov file to divx (mpeg4 video/mp3 audio) with sound?
What am i doing wrong?
Mr.Ash5Guest
Quicktime gives me the following information.
Video : mpeg-4 video 16,7mio colers 752x576
Audio : ulaw 2:1 stereo 32000Hz
Framerate :25fps
It's a Quicktime .mov file.
Mr.Ash5Guest
No, has no sound!
The file i tried to encode is a QT .mov file witch was captured from my TV-card. It is possible to create a SVCD with ffmpegx, but only when i select "decode with QT". The problem with no sound only apears when i try to encode with the "ffmpegx" or "mencoder" codecs.
I just want to capture my old VHS tapes and then transcode them to divx .avi's using ffmpegx. The only problem is, the encoded .avi file's have no sound.
Mr.Ash5Guest
Yes, now it works. Perfect mpeg4 .avi file with mp3 sound. It would be great, to include this AVI tool in ffmpegx. Or even better: make ffmpegx to work with these kind of .mov files in a future release. Thanks a lot for your great app and even greater support Major.
whitedbGuest
It can also be that the sound from your movie is on the wrong channel.
With the 5sec preview, try different audio track inputs and see if that fixes things.
Mr.Ash5Guest
Yes you're right! I found the sound on channel 1, but it's in an extreme bad quality. But that's no problem anymore, thanks to Major's hints.
For some reason it's not possible to encode the the .mov file with the ffmpeg engines. You must chose mencoder engine or mpeg2enc engine. When you use the mpeg2enc engine then you must chose "decode with QT", otherwise it won't work either ("decode with MP" doesen't work!)
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 12:48 -
Program to split .mov files without re-encoding
By Guest in forum EditingReplies: 5Last Post: 21st Jul 2010, 21:09 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 09:26 -
DV AVI to DV MOV - without re-encoding?
By arminio in forum Video ConversionReplies: 2Last Post: 4th Mar 2008, 05:42
