I hope I got the right forum their was no specifically applicable forum so I picked the one that was "closest"
How do I do this. I tried to treat them (svcd's) like dvd's
copy mpg's use dvd2avi to make the mpa and d2v file so far so good.
but when I use tmpgenc to convert to mpeg1 (I do everything in mpeg1) it works but no sound. yet when I dump the mpa into a winamp it plays fine so I know their is sound their. I assume that tmpgenc just can not handle the mpa file ? I can convert it using goldwave into a wav file (boy does that add a huge step hence why I really do not like svcd's they are a royal pita :-)
is their an easier way to get the audio out to something that tmpgenc will like when I tell it to make the conversion ? Can dvd2avi work or is their another equivalent for svcd source files or is their something I can do to tmpgenc to make it take the mpa's
Any suggestions are much appreciated.
Chris Taylor
http://www.nerys.com/
