whenever I try to load the .VDR file, CCE 2.5 SP simply just crashes...no error messages or anything, simply quits running.
Adding an .avi in CCE works fine though ..
Also when I use DVD2SVCD I get great quality so CCE works perfectly then...
Any suggestions ? I'm running Win2000 on an athlon 900, 384Mb
Install the handler and run proxyon.reg before starting the frameserver. After encoding run proxyoff.reg, otherwise you get problems with VFAPI.
Officexp 2002 won't accept my serial to put back MS Word
By abrogard in forum ComputerReplies: 10Last Post: 21st Oct 2008, 01:09 -
Vegas 6.0 Won't Accept mov file
By solarblast in forum Video ConversionReplies: 18Last Post: 18th Oct 2008, 11:17 -
Imac won't accept blank DVD-R DL with Toast????
By dunpal in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 18:04 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 15:57 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 16th Apr 2008, 00:04
