Hi. I recently purchased a Pioneer DV-563A DVD player. I also recently got some burned DVD-R's from a friend of mine. Of them, two will not play on the player. I've tried them both on my DVD-ROM drive and both work. However, I noticed that, while the ones that do play on the Pioneer have basic text menus, the two that don't have menus with text and an icon of the first frame of the files. So, I was wondering if that could be the reason they don't play.
Also, I had called Pioneer's support on this. They said that if the DVD-R's were recorded in anything other than the two-hour mode they would not play on the player. Is there any way I could find out what mode these discs were recorded in to see if that is the problem?
Thanks a lot for any help you can give.
Kevin
Results 1 to 1 of 1
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 16:35 -
Question how to make srt/avi subtitles bigger when playing in DVD player
By jimdagys in forum SubtitleReplies: 6Last Post: 24th Oct 2008, 01:10 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
Intresting Dilemma with burning and playing DVD-Rs in my DVD Player
By John Shumate in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 03:53
