i got theTMPGEnc program to encode a VCD and put it on a DVD. It worked the first time with out a hitch. But when I went to encode the second part I tried doing the same way as the first part and it me a error. It said that the file cannot be open or is unsuported. I don't understand this because I am doing it the same way as the first setion and it is the same file type. Please tell me of the reason it does this and how to fix it if it is fixable.
Dear kg4ooz in Kentucky,Originally Posted by kg4ooz
Your message may seem logical to you, but it is not to me. It gives too little information.
A. No AVI or MPG is exactly like any other.
B. What do you give TMpgEnc to create a VCD of? Is it an MPEG-1, MPEG-2 or AVI file, and is the latter "original" AVI (which comes in Gb's for a comparatively short recording time) or MPEG-4 encoded AVI, like DivX, XviD, 3ivX or what have you? They all have their particular problems.
B. If it is MPEG-1 or MPEG-2, the standard procedure in case TMpgEnc refuses it, is to load the file into VirtualDub-MPEG2, save out the audio as a WAV file, frameserve the video to TMpgEnc and feed TMpgEnc the WAV file for audio. (Don't use the Wizard..)
Look for Guides about FrameServing in other parts of this Site.
Hope this helps at least a little.
Callan -
I think this post is in the wrong location, because I have the same problem:
I just found this and it might help: https://www.videohelp.com/tmpgenc.htm
scroll down to Problems and Tips
Looks like we may need come codecs, (when I get home from work)
Unable to install avisynth: Error opening file for writing
By ximon in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2011, 18:52 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 22:48 -
GUI for DVDauthor - error opening MMbackg.mv2 file
By PCH in forum Authoring (DVD)Replies: 27Last Post: 24th Jul 2008, 04:20 -
error when opening up mkv file with virtualdubmod
By parth82390 in forum Video ConversionReplies: 5Last Post: 5th Dec 2007, 19:00 -
Error when opening avs in VirtualDubMod
By chrishallowell in forum Newbie / General discussionsReplies: 6Last Post: 28th Aug 2007, 08:57
