i can't seem to copy my rush hour 2 dvd, its the version that has all the infinifilm crap on it, and it just freezes any ripping program i use at like 15%.........the speed drops to 0.0x and the counter continues but no more ripping is done........i have tried to use smart ripper, dvd decrypter, and dvd fab 1.52, and to no avail have i had luck......they all freeze at 15%........anyways, i wanted to know if there was a way using any of these programs at all to even get the files on my hard drive, it would be nice to have.....by the way i have tried to watch the movie and it does that fine....thanks guys
Results 1 to 19 of 19
try cleaning the disc. brasso + armor all works well if you copy is scratched to hell(yeah im a beleiver now)
yeah i already tried cleaning it, but whats brasso??? and u can use armor all on a cd? which kind, like the kind for the dash of a car? thanks
Brasso is a brass (or other metal) polish. Search the forums here for Brasso and Armor and you'll find lots of references to people cleaning their DVDs with Brasso and Armor All. Seems to work.
Try just doing a straight copy to your hard drive and then use something like DVD shrink on it there to decrypt it. DVDshrink can import DVD files on the hard drive if they are in a VIDEO_TS folder.
DVDdecrypter can only import files from an optical drive.
Worth a shot. -
yeah i think ive already made a backup of this movie with shrink with no probs. i did a re author though and just pulled the main movie. brasso=$2.64 at super walmart(cleaning section next to tarnex and all that crap), and armor-all=$2.50 at super walmart(auto section)
when i try to drag and drop the files to my hard drive, it does the BUP and IFO files no prob, but all the VOB files give me an error when i try to drag and drop them that says "Cannot create or replace VTS_....: File system error (-2147351799). What do i do? It seems impossible to get these freakin files off of this cd, but i know there is a way....any ideas whatsoever???
I know I've done a direct copy of a DVD to hard drive in the past without a problem, but couldn't play the files because they were copy protected until I uncopy protected them.
I don't have this particular movie, so I can't test it out.
Probably something with that specific disc or that one specific VTS you are having trouble with.
Did you try Main movie only?
So I assume the Armor All didn't work? -
The disc might have a error on it just a bad burn and it can not copy a the error I had this happen with a disc I want to copy that I bought I brought it back got a new one and then i could make a copy its very rare
Try to extract the files through isobuster.....it has a way of bypassing some windows crap
http://download.com.com/3000-2248-10208088.html?tag=lst-0-1 -
It is a wierd DVD ... I had problems with the subtitles.
Uh ... you could buy it.
But even then the subtitles behaved wierd on mine. -
Why do you think it is a piece of crap ??Originally Posted by richdvd
LOL, you guys are too much.Originally Posted by richdvd
I only know-I know nothing. -
Yeah i had that happen one time, i was trying to rip it with dvd shrink and it kept freezing at 86% and the dvd was new so i went and rented the dvd for free and it ripped no problem. I was only doing that becuase i was selling the original and wanted a copy of it...Originally Posted by spiderman2k1
I ripped rush hour 2 with no problem using dvd shrink, i just still frame all the extras and leave the movie as is -
had no probs with RH2. if you cannot find Brasso any automotive polish that does not scratch will work. i use a auto polish that is finer that a polishing compound (which is finer than a rubbing compound) but is not as fine as toothpaste on a disc that was totally scratch. after rubbing it out twice almost all the scratches were gone, and no new scractches introduced. DVD Decrypter ripped it in record time with no errors! i got the polish about 10 years ago from an auto store for a dollar (clearance item). use it to rub out my woodworking projects. works a lot better than steel wool or the new synthetics. and is NOT silicone-based.
also you might try a mag wheel polish. they do not scratch, and is more "gritty" than toothpaste. also i do not use armor-all or its like. good luck. -
What the **** has that got to do with the topic?Originally Posted by richdvd
If you can't help, don't post, or is that premise too much for you?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I very much agree with ... Will Hay ...Originally Posted by Will Hay
Let us help people ... not criticize people for different tastes in entertainment. I like Rush Hour 2 ... lots of good comedy.
Especially the scene where the American cop says ... " He wont be in Rush Hour 3"
Cant copy Rush Hour 2
By websurfer in forum DVD RippingReplies: 2Last Post: 9th Aug 2009, 21:45 -
Ripit4me Rush Hour 3 backup problem
By TheButcher69 in forum DVD RippingReplies: 14Last Post: 1st Feb 2008, 14:16 -
Rush hour 3 backup not working
By tim_ver in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2008, 21:49 -
Rush Hour 3 - Why is the RipIt4Me failed?
By coody in forum DVD RippingReplies: 6Last Post: 8th Jan 2008, 13:19 -
Rush and MVI format discs.
By dphirschler in forum Latest Video NewsReplies: 1Last Post: 14th Jun 2007, 10:39
