Can someone help me with this?
The project uses various video sizes on one DVD:
- You mix SIF and Full D1 video Streams
- Some DVD player may have problem to play suck disc
- If possible, use the same size video streams for best compatibility
This was in "Errors and Warnings" window in DVDlab.
One titleset must be all the same resolution and audio. You cannot have 720x480 and 352x480 in the same titleset.
I'll assume that you are using VTS method of compiling the project. If you are everything must be the same, the video and audio for the movie as well as any video and ausio used for the menus(if any).
You have 2 choices. Re-encode the videos so they are all the same resolution, frame rate and audio type, or use VMG compile method, where each differing video and audio is in it's own titleset(required DVD-Lab 1.4.1 beta 1 or higher to do). If you go the VMG way, there are tutorials on the DVD-Lab website that show you how to build a multi titleset project.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
External Hard Drives...How Full Is Too Full?
By bbanderic in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2010, 18:25 -
Mix full d1 and broadcast d1 DvdLab Pro 2
By subba in forum Authoring (DVD)Replies: 12Last Post: 29th Oct 2008, 08:03 -
line 2207 of the inf file \dell\txtsetup.sif is invalid
By SIRCOOKS in forum ComputerReplies: 2Last Post: 17th Mar 2008, 13:26
