I use an ATI All In Wonder Radeon TV Card in my PC. When I run composite cables from my VCR to the PC, and try to capture using VirtualDub, I can capture video that I originally recorded off a source to a blank VHS tape, but when I try to capture from a store-bought VHS tape, the audio is fine, but the video is just a green screen. Do manufactured VHS tapes contain some kind of copyright protection encoding that is causing this? If so, is there any way to get around this? I want to do a legal thing, which is just to put the video on another media for my own private use. Any help would be appreciated.
Results 1 to 12 of 12
Commercial tapes are protected with a scheme known as Macrovision. That is why you see the stuff on the screen that you do when attempting to copy a commercial tape.
Yes, after doing a little research, I see there's a device manufactured by SIMA. It's called the Copy This! Video Enhancer. It's $60 at the Best Buy website, but they don't seem to have it at the retail stores. This device promises to remove Macrovision, and accomodates either composite or S-Video inputs/outputs. Now I have to decide if it's worth that kind of money to copy my store-bought VHS tapes to DVD.
Originally Posted by waldodio
She-it. My wife will want me converted to that religion!
Never used the Sima products, but a dedicated TBC will work as well. -
Originally Posted by racerxnet
Send her over here with a six pack, and all your DVDs
and I'll work on it. -
OK, I can convert anything from vhs to DV on my pc for dvd or vcd authoring and remove macro. I use a sony dv cam and use the vcr out to my cam then a firewire to the pc. I remove the tape from the cam and it automatically sees the vcr playing the movie. ie. I have all 3 original Star Wars flicks on DVD because of this and I heard you can do this with some other capture devices, BUT not a pc card. Any hardware installed on a pc will have copywrite protection, but the firewire system works, AND its a better quality cature than any card installed on the mainboard. PS, try to obtain Sonic Faundry or similar software. Pinnacle is easy to use, but the audio/video sync is terrible, and seems to haunt pinnacle software.
also, the cam trick works with dvd players too, BUT all u need to do is download DVD shrink or DVD_decrypter for that and dump it right into your pc anyway.
Is DVD Shrink only for copying a DVD located in a DVD drive within the PC tower, or can it work for analog video being fed from an outside source, such as a VCR?
There is a little device you can buy thats built into a scart lead, which will remove the macrovison protection
Its on the 'net, can't remember off hand where, but I'll have a look later and post the link when I fidn it again
Cost about £30, which is just guessing about $45
As far as you can see, its a normal scart lead, but the electronics are built into the scart plug itself
Copyright and Child Protection when videoing
By IKnowNothing in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 09:23 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
Panasonic DMR ES20 . copyright protection? CPRM? FR mode no pause etc
By texas1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 2nd Mar 2008, 13:10 -
key exchange for dvd copyright protection
By repeatrepeat in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2007, 23:54 -
VHS Copyright protection
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2007, 05:57
