I've noticed people refer to bitsetting from within their burning program, and it supposedly changes something on the DVD. What is this all about and what is the purpose? Thanks.
-Brian
Results 1 to 13 of 13
It sets bits.Bitsetting...what does it do?
No but seriously...it makes the dvd player playing the 'bittset-ed' dvd think its a different format. Example: A dvd-r that you bitset 'transorms' into a dvd+r. But not really transforms, since it doesnt change anything esxcept what the dvd player sees it as. Get it? I dont even understand what i typed...-Yar, matey!- -
I've seen that people like to change discs to DVD-Rom. What does that accomplish?
The reason you use bitsetting on a dvd+r(bitsetting isnt used on dvd-r)is to set it so dvd players recognize the dvd+r as dvd-rom which allows for more compatibility.
I've also heard that making DVD+R bitset to DVD-ROM makes them readable in X-box/PS2. Supposedly, these gaming systems look for the DVD+R media type and refuse to play them.
I haven't verified this myself. -
CompatibilityBitsetting Overview
http://www.dvdplusrw.org/Article.asp?mid=0&sid=2&aid=42 -
I used the Booktype tool on a + to play in my g'daughter's PS2, and it works fine. It would not play either - or +. RW, I don't know.
Others have posted that their's do play them, but there are ar least 7 versions of PS2.
Have to try one in my daughter's Samsung. It has never played anything I have burned, fromVCD on up to DVD- or +.
If it plays there, I, for one, will swear by it. All the posters in DVD Players to the left say hers plays anything. It does NOT.
Cheers,
George -
To give a quick summary (of my understanding at least
Playing a DVD can "not work", at two different points in the process.
A. The DVD player reads the book type of the DVD and finds a format that it either doesn't recognize, or doesn't like.
B. The DVD player attemps to play the video/audio stream off the DVD and has problems reading it (skipping, graphical issues, just plain not seeing any info at all, etc).
So what bitsetting is, is to "fake" the book type. Set a DVD to the "DVD-ROM" (ie. pressed dvd) book type. Why would you do this? Presumably to defeat type "A" problems like described above. Where a DVD player goes "DVDr, what is that??? I have no idea how to play a disc of that type" or "DVDr, well thats not a pressed dvd. For copyright reasons I will refuse to play it!"
So it gets you past that step, where a DVD player just plain refused to even try reading the disc. However, it does nothing to address type B problems, where the player, bless it's soul, just can't read the data off the disc.
(Book type of a DVD is something that describes it's type, eg DVD-ROM (Pressed dvd), DVD+R, DVD-R, DVD+RW, etc etc. Basically it differentiates between recordable and pressed media. More significantly, it's something that can't be changed. Presumably it comes pre-written on the media when you buy it blank).
All in all, a neat little trick, although how useful, is somewhat debate-able.
Finally, such a "tricK" can only be used on +R discs. Even more so, only on +R drives that support this feature.
I'd imagine you can do it with +R media but not -R because on -R blanks the book type is pre-written at the factory, while on +R discs they rely on the drive to fill in this info? (I'm not really sure on that one).
"Bitsetting" is a rather uninformative name for it. (Gotta love people and their penchant for "tech" sounding buzzwords...)
Aggies -
How old is that article?My liteon 411s which is dual dvd burner can do bitsetting.Originally Posted by tompika
Well, yeah, things have changed since last September but its still a great article about bitsetting
I forgot to link to the list of the drives that can bitset.
https://www.videohelp.com/dvdwriters.php?DVDname=&cdrs=&cdrws=&dvdrs=&dvdrws=&dvdprs=&dv...&Search=Search -
I noticed my Memorex 8x dual format burner isn't on the list. Does that mean it can't bitset, or it hasn't been confirmed yet? Thanks.
Brian -
Depends what drive it is inside.Originally Posted by briandugas
If LiteOn, the LiteOn bitsetting tool might work
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 13:39 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 10:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 13:58 -
Enabling Bitsetting on Pioneer DVR 215
By here2rock in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Aug 2008, 04:29 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 22:33
