I installed my hercules smart tv (stereo) on windows XP, and it works like a charm, I install it on 2000 and it doesn't work (and this is the second time I tried it on a new windows install, and it has worked before!!)
There's always this problem: Ole32, it keeps crashing everything....
It doesn't make any sense, it's like windows media encoder, it used to work on my system, but now it doesn't, no matter how much I reinstall an OS.
When I open powervcr or virtualdub or iuvcr, and they crash, I can leave it open before I click the 'ok' button, then I can open another instance of iuvcr or virtualdub, and then I can access the capture device, but I can't use the tuner... I already tried a lot of different drivers
Edit: Ok, so I did a search on the forum and apparantly, it's because of the k-lite codec pack. I hope this thread can stay to help people fix the problem.
Results 1 to 1 of 1
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Core2 Quad with Windows 2000?
By SatStorm in forum ComputerReplies: 18Last Post: 21st Aug 2007, 18:29 -
Windows 2000 Hotfix
By MarioB in forum ComputerReplies: 13Last Post: 18th Jun 2007, 13:39 -
Windows 2000 options, if any.
By AlecWest in forum Capturing and VCRReplies: 6Last Post: 18th Jun 2007, 00:22 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
