Does VOB obtained from DVDDecrypter contain all the angles and sound streams (such as 7.1 and 5.1 English, French...)?
Depends on what settings you select.
For the most part, unless you use 'Stream Processing' all languages, subs, etc., will be included.
But that may or may not be a good thing. What are you trying to do? -
Thank you for your answer.
I want to take out the desired songs (chapters) from several Karaoke DVDs, and create a new Karaoke DVD. Do you know how to accomplish this? -
I've never ripped from a Karoake DVD before, but I assume it's similar to any other DVD...
What you'd want to do is use the 'Stream Processing' function in DVD Decrypter and rip each "chapter" (song) individually. Then use a DVD authoring program to author a new DVD from the VOB's you ripped. Many guides to the left on how to use DVD Decrypter and authoring programs.
Might also try DVD Shrink, if all the songs you want are on 1 DVD... you can "re-author" with that app to keep just certain portions of a DVD. Would have no menu, though. Again, guides to the left for that app too.
Good luck. -
Hi
I used NERO RECODE then one of the option in there is to Create from multiple DVD. I used that then after you import the DVD, then add then you will seee one of the option in there that said Start/End click in there then select the chapter you want. I usually burn it to my hard drive for each DVD Karaoke (song) then until i have enough for one this then I'll used Clone DVD to burn everything in one disc. The audio and stuff are the same format..you'll be able to select audio1 and audio2
Hope it helps
Khoa
PM me at Yahoo messenger : kphan78 if you have any question .lana
email: kphan78@yahoo.com -
Hi, I have successfully created a compilation of Karaoke songs with dual audio tracks (so you can turn on/off the voice) and selectable menus as well as navigation with the NEXT and PREVIOUS buttons on your DVD Player remote control.
First you can use DVD-Shrink to extract the Karaoke songs that you like onto the hard-disk (I place each song in one separate folder). Then I use DVD-Lab to import the VOB files of the songs and create one title per song. I then create the menus from where you can select the songs, I put 6 songs per menu. You can not test the navigation functions NEXT/PREVIOUS using PowerDVD on the computer, but the function will work on your stand-alone DVD Player using the remote control. Please refer to the different guides on the forum on how to use DVD-Shrink and DVD-Lab. Hope that this will help anybody who wants to create personalized Karaoke DVDs with selected songs. It works very well for me.
PM me at Yahoo messenger : kphan78 if you have any question .[/quote]
Single large (over1gb) vob into a Simple no menu DVD ?
By nerys in forum Authoring (DVD)Replies: 11Last Post: 28th Feb 2011, 21:27 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 09:27 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 06:12 -
Super Simple Free VOB to DVD program desired
By nerys in forum Authoring (DVD)Replies: 3Last Post: 2nd Sep 2007, 17:13
