Hi
Because prices of DVD RW disks is very high in Iceland I used drag and drop to copy files recorded by my Philips DVD Recorder to a PC harddrive. Then I could use my DVD RW disk again and the files were save. I thought I could then copy them back to the DVD RW disk to watch but now my Recorder will not play the disk. I can play it on my PC though
Any help?
Keli![]()
Make sure your VIDEO_RM folder is all in caps or the recorder won't be able to play it, to bad about the High Price, here in the states I pay $2.50 for my +RW for my Magnavox(revamped Phillips). I use TNPGE DVD author to grab my +RW media, edit , reauthor then burn them back on cheap DVDR media, erasing the +RW's for future uses.
Movie Factory 3 also will stream the +RW for you also. Both have trial versions to can try for 30 days -
Hi
Many thanks for taking time to look on my problem. I will try your solution and let you know.
Regards,
Hrafnkell -
ur problem could also be down to how ur burning the dvd, eg as an iso or dvd video, if your using udf modes or forced compatibility etc, ur player may be picky about these options, i use copy to dvd reauthored disc images and it always hits the mark
Philips 3455dvdr stays on philips logo
By vbdanl in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Sep 2010, 11:15 -
DVD Disk Lock??? i locked my dvd player i need password! (PHILIPS DVP3520)
By kamzo91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Aug 2010, 15:14 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Moser Baer DVD+RW Burnt As Data DVD Freezes In Philips DVP 642K
By yohu123 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Sep 2007, 13:51 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45
