How? Thx.
change the file extension. this works for most applications that won't accept a vob. a vob and a mpeg2 are basically the same except a vob can have extras in it.
Womble Video Wizard will accept VOB's and spit out an mpeg. Not free though there is a 30 day trial.
"Art is making something out of nothing and selling it." - Frank Zappa -
Ok, Im trying out Womble Video Wizard. Can you tell me where within the program I can take a Vob and spitt out a Mpeg?Originally Posted by ZippyP.
Also, how do I change the file extension? -
You don't need to change the file extension. Import your vob(s) and put them onto the timeline, you can do it one at a time or all at once. Just drag and drop to place them. Then select export to save it out as an mpeg.
Ok, I can now ecode it to Mpg, but can I do it without encoding? Please be specific for dumb me. Thx.
Womble doesn't encode it unless you make changes to the file, like adding titles, transitions or other affects. If you put it on the timeline then save (export) it just extracts the mpeg2 video from the vob. It will convert the audio to mpeg1 layer-2 (MP2) if necessary and then multiplex the A-V streams into an mpeg file.Originally Posted by JackMartinEF
BTW, you can edit out portions of the video before exporting and it doesn't need to re-encode.
Hope that helps."Art is making something out of nothing and selling it." - Frank Zappa
Several movs/mpgs to DVD / Quality decreases on best files
By soundchaser in forum MacReplies: 4Last Post: 2nd Nov 2010, 11:04 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Change default audio in .VOB or .MPG files
By dsmith1984uk in forum AudioReplies: 1Last Post: 4th May 2010, 05:10 -
VOB Files Change Durations!?
By ronsweet2 in forum Newbie / General discussionsReplies: 5Last Post: 6th Jun 2009, 04:09 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37
