I've searched for this in the archives, but there are no good answers.
I want to make an action scene DVD; taking many small clips and burning them onto one DVD. I would like to remove the chapters which are pre-built within each clip and create new chapters that start with each new clip. How can I do this?
I assume your clips are already authored in a DVD (since you have chapter points).
With TMPGEnc DVD Author you can import it as DVD-Video. In the Add DVD Wizard, in the option settings, uncheck "reading chapter information". Then in the "chapter cut edit" you can set the chapter points where you want. -
What are your video sources? WHich authoring software do you have if any?
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 17:27 -
Adding chapters to .pm4 video to burn to dvd ...
By CaptainChaos in forum Authoring (DVD)Replies: 2Last Post: 13th Sep 2009, 05:54 -
Adding chapters to DVD project in TMPGENC DVD Author
By robertazimmerman in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 10:09 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 19:53 -
adding chapters to a dvd
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 08:02
