Hi,
I am wondering if capturing with onboard sound is the culprit to my sound volume fluctuation issues?
I've an ASUS TV Tuner - TV In Capture card, (TV880), P4, Win XP, 1G RAM and onboard sound.
While WATCHING cable TV or VCR tapes, the sound is excellent, with no fluctuation in volume.
However, while watching PLAYBACK of the resulting mpeg file, the sound is choppy and cyclical in volume - louder at some times and lower at others.
This has occured in both TV Cable and VHS captures, and with four different avi capturing programs as well, (PowerVCR, IUVCR, AVI_io, WinDVR).
I read somewhere that some capture cards do not recommend using onboard sound, but actually recommend a separate sound card. Would this issue only arise in playback of a captured file?
Would getting a separate PCI sound card, with its own processor correct this issue of fluctuating sound volume after capturing?
If onboard sound as opposed to a separate sound card is not the solution, then would I need a different capture card?
Thanx!
John
Please do not cross post. One topic is enough. Other topic closed.
/Moderator - Bugster
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
discrete sound card vs onboard quality
By mammo1789 in forum AudioReplies: 1Last Post: 17th Dec 2011, 08:53 -
Mobo with onboard graphics or separate card?
By Deisel Weisel in forum ComputerReplies: 11Last Post: 21st Sep 2010, 22:35 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Build-in or separate video card for TV and capturing
By DeafBug in forum ComputerReplies: 3Last Post: 16th May 2007, 17:03
