I am having two perplexing problems with capturing from analog video (vhs tapes) to DVD. My computer has a 660 mhz processor, a 20-gig hard drive, and a Radeon all in Wonder 7000 capture card. I am pulling my signal with a composite cable through a DVD Red Pro to remove macrovision. 90% of the time I am getting good captures, but the rest of the time I am having two daunting problems. The first is horizontal "tearing" - the picture will be fine, then suddenly the picture will start pulling and tearing horizontally, also jumping, sometimes to the point that the capture card loses the signal. When this happens, the Red Pro is not indicating macrovision is present. The second problem is high brightness - as though the brighness control was turned all the way up. This is consistant throughout the capture, but only with certain source tapes. Again, the Red Pro indicates no macrovision. At times, I use a splitter and monitor the video on a small television, and these problems do not show up on the second monitor (I usually do NOT use a second monitor becasue it weakens the signal). Is there another filter besides the Red Pro I should be using to eliminate these problems? Would a video amplifier (such as used to drive several monitors from one source, like in a car with multiple screens from one player) alleviate the problem? I am a new member to this board.
Results 1 to 1 of 1
How can I correct severe tearing during VHS capture?
By Sparrowhawk in forum Capturing and VCRReplies: 11Last Post: 3rd Apr 2011, 18:31 -
Horizontal Tearing
By Tripledrop in forum Software PlayingReplies: 0Last Post: 16th Mar 2011, 13:57 -
Hair tearing H.264 and .mov problems!
By Nintendo Fan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Mar 2009, 16:16 -
AVerMedia A180 input capture problems - random short horizontal lines
By Rezolution11 in forum Capturing and VCRReplies: 0Last Post: 17th Dec 2008, 15:25 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53
