Can anyone help me with this please?
I have captured a 70mins VHS tape to my hard drive via my pinnacle DC10 card using studio 8.
I imported the captured avi file into Ulead DVD Workshop and created chapters and then set the software to make a DVD+RW disk after encoding at the good quality setting eg. 190min DVD disk.
The problem is that when viewed on TV fast moving objects have zigzag type lines on edges of objects like cars etc.
Help please!
This sounds like a field order issue. You need to reverse the filed order setting in Workshop and re-do the video.
Thanks Bugster.
Had a look in workshop and cannot find a reference to field order.
Have you set this yourself? If so how?
Thanks again. -
I am not familiar with workshop so can't help you with that. It's just a setting that any mpeg-2 encoder should have. Take another look or try the help file, it should be there somewhere.Originally Posted by petrolhead
Problem with motion getting jagged lines
By philflo in forum Video ConversionReplies: 2Last Post: 6th Mar 2012, 09:27 -
Edges look jagged, and lines across the video.
By killerteengohan in forum DVD RippingReplies: 18Last Post: 29th Jul 2011, 14:18 -
Jagged lines upon playback
By seven_deuce offsuit in forum Video ConversionReplies: 10Last Post: 17th Jul 2010, 09:31 -
Why does this x264 encode from DVD have these jagged edges?
By Obelik in forum DVD RippingReplies: 7Last Post: 17th Apr 2010, 01:59 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 23:35
