HELP!!!!!!!!!!!!!!!!!!
I have recently " aquired " a movie, which I have received as a bin & cue file...
These files, when written on a CD become a VCD. The problem that I have is that my dvd player will play DVD-R, but not VCD.....
Is there any way that KI can convert these files into DVD format?
Any help would be greatly appreciated as I am completely stuck, but at the same time convinced that there must be some way.
Is there no way to do it so that you don't lose video quality???
If not, how do I do this anyway?
cheers! -
You can do it without losing any video quality (compared to the original VCD) as VCD video is DVD compatible (no reencoding required). Just extract the mpg from the VCD image using VCDGear (or VCDEasy) and author as DVD with TMPGEnc DVD Author.
/Mats -
You also need to resample the audio from 44.1Khz to 48Khz to make it dvd compliant
resample the audio from 44.1Khz to 48KhzEnen if I haven't tried it myself, judging by many posts here, TMPGEnc DVD Author does that "automagically" if you choose a VCD compliant mpg as source material.So how do i go about that then????
/Mats
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
