Hello ppl,
I was looking for your thoughts on the following; I have some DivX .avi files I’m looking to convert to mpg format for DVD. I’ve been looking at some converters like CucuSoft and other programs like that but these programs don’t let you set the maximum size of the output file so it can safely fit on a DVD.
So can anybody recommend a fast converter and also one that can set the final size so after 14 hours of converting it will fit on a DVDr.
Thanks...
Results 1 to 11 of 11
Canopus Procoder is also good, but much more money than TMPGEnc (which is also very good)
Thanks for the help, i had a look at Canopus Pro and it seems to do the trick, I'm converting at 6.5fps now instead of 3 and 2.5fps with SuperDVD and CucuSoft...
Thanks again... -
Depends on how the audio is encoded. If it has a variable bitrate TMPGEnc does not handle this well so you need to save the auudio stream as an uncompressed wav file (virtual dub can do this) and use this wav file as the audio source in tmpgenc.
hey,
Does anybody know how to use canopus procoder to convert vob files to mpeg?
thanks -
someone wrote a post the other day on how to set vobs as input type. look through the search and see if you find it. lata.
https://www.videohelp.com/forum/viewtopic.php?t=209554&highlight=canopusOriginally Posted by dselwyn
Good AVI/etc to DVD converter?
By Jim200 in forum Newbie / General discussionsReplies: 8Last Post: 19th Aug 2009, 16:37 -
DVD to mpeg or AVI etc converter
By booyaka in forum DVD RippingReplies: 1Last Post: 15th Dec 2007, 03:43 -
dvd to mpeg or AVi converter
By booyaka in forum Authoring (VCD/SVCD)Replies: 1Last Post: 15th Dec 2007, 00:17 -
RM to DVD used AVI converter got no sound
By warblerchi in forum AudioReplies: 1Last Post: 16th Oct 2007, 20:30 -
Best converter DVD to AVI
By Deaf Raiders in forum DVD RippingReplies: 1Last Post: 4th May 2007, 08:42
