Hello,
Do we have any free and easy tool to convert DVD to standard MPEG2 files and in process reduce the bitrate < 3mbps and bring the subtitles.
I am novice and if some can provide exact steps in detail, it would be great. I want few movies to be playable through my networked dvd player. It only accepts standard MPEG2 (with bitrate < 3Mbps).
I can use dvdshrink/dvddecrypter to make vobs usable by other tools.
I tried tmpgenc and it appears to be working but is just a trial version and actual version is very costly.
Thanks,
jaz.
Results 1 to 9 of 9
Originally Posted by zdvdrhelp
Back to TMPEG. It runs like $60 bucks. That works out to be "very costly?" -
yeah..i mean steps to convert using ffmpeg from vob to standard mpeg and reducing the bit rate to < 3Mbps. I visited that ffmpeg site, but couldn't find easily binaries for windows (appears that it needs compilation). If you can provide the link for binary download for windows, it would be great. Thanks for your help.
For the ffmpeg binary, I think someone posted a package in the tools section of a GUI front end for using ffmeg to do some audio conversion that included the binary.
As for a step-by-step guide, I know of none. I think the difficulty in finding a binary or a guide re-inforces what I said earlier. ffmpeg is a hit or miss proposition on windows, if only because, at this point, there is not a community of users.
I still don't understand the resistance to TMPGenc. If you only have a few movies to convert, then just use the 14 day trial. If you can't do what you want to do in 14 days, then it would seem that the ~$60 for TMPGenc would be a diminishingly small fraction of the price of the DVDs and the network media player. It's your money and your time though.
Good luck. -
Originally Posted by zdvdrhelpWant my help? Ask here! (not via PM!)
free tool to convert m2ts to mkv ?
By tagada45 in forum Video ConversionReplies: 7Last Post: 17th Feb 2014, 06:28 -
Looking for a free tool to convert AVCHD to the .MOV video format
By coody in forum Video ConversionReplies: 3Last Post: 15th Sep 2011, 12:05 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Is there any free reliable tool to convert the .mov to MEPG?
By coody in forum Video ConversionReplies: 1Last Post: 12th Dec 2008, 20:05 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51
