question: I have about 8 gigs of video clips I've downloaded over the years that I'd like to burn off to DVD for backup. I tried it once as DVD Bridge format (UDF1.02/ISO) and it works okay but playback directly from the disc is jumpy. Is there a better way to burn it so the clips play back correctly or is this just a result of the way the drive reads the disc? I can copy the files back to the HD and they play just fine. Maybe a different version of UDF or burning DVD-ROM ISO would be better?
Just burn it as a data disk, then it will play back correctly. I don't know what format that is in Nero. I only use the wizard, Nero StartSmart. Works every time
I'll have to try the wizards then instead of wasting more DVDs. I usually just use Burning ROM, but I don't typically burn data DVDs.
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero Help with Data Tracks
By KnucklesNilan in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 10:06 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 16:00 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
