I'm making a DVD slideshow and i go to render my movie it goes through and renders it then when it says its about to write to disc i get this error
Video Stream Contains unexpected data in front of sequence header.
Does this mean my DVD is bad or what im not sure please help.
try creating the disc content in studio 9 and burn it with nero. Do not trust the DVD burning in Studio 8 or 9.
alright i will do that, now do i take all the files that Pinnacle spits out and burn them to the DVD or only certain ones?
UPDATE: Well i get the same error when trying to do that again i guy im going to have to start the project all over to see if that will work. -
Have you downloaded the new update for 9? I would also try and delete all the auxillary files. You can do this under File and select delete auxillary files. Then try and make disc. If this does not work, try and make movie, then create a new project and load the video file make movie creates and try to make a new disc.
Not sure what kind of error is that, but here is guide for burning with another tool.
Pinnacle Studio - prepare DVD content for burningPinnacle Studio 8 and DV home video editing (ver.9 already home)
Smooth Panning in Picture Slideshow using Sony Vegas Studio.
By HoosierGuy in forum EditingReplies: 6Last Post: 8th Jul 2011, 23:15 -
How to make slideshow from jpegs (for MS PowerPoint)
By StephanJohn in forum Newbie / General discussionsReplies: 20Last Post: 24th Aug 2009, 13:06 -
I need to make a simple slideshow DVD
By jeffzilla in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 02:52 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53
