how do i uninstall a codec, say AC3 from AVI Xform. Since it doesn't seem to fking work.
-RoMeRz: Don't stay still while walking...
AC3 to AVI XForm is actually a FILTER named "MPGAudio.ax".
I keep mine in the system32 directory of my win2k machine, and can unregister it by typing at a command prompt;
"%WINDIR%\SYSTEM32\REGSVR32 /U MPGAudio.ax" -
You can use the Device Manager and look under Sound, video & game controllers.
Look for the Audio Codecs - right-click & select Properties.
The Properties tab next shows you installed audio codecs.
You can use the Remove button to uninstall any.
Martin. -
install this free app -- http://www.analogx.com/contents/download/audio/dxman.htm
and have complete control over all your codecs -- even many that dont show up in device manager"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
question about difficulty in uninstalling file
By jimdagys in forum ComputerReplies: 3Last Post: 28th Mar 2008, 09:52 -
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 08:37 -
Uninstalling this utorrent program
By vipertongn in forum ComputerReplies: 7Last Post: 5th Aug 2007, 07:17 -
Trouble uninstalling dvd43 - help
By NitroxAZ in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 22:43 -
no audio device after uninstalling antivirus?
By Rudyard in forum ComputerReplies: 4Last Post: 23rd May 2007, 21:19
