Hi
I have a dvd burner and would like to back up some of my dvd's. The drive can not do a direct dvd to dvd copy as it can not right to the copyright part of the disc however is it possible just to copy the files from the dvd to the dvd-R without having to reencode them to mpeg2 using tmpgec etc??
Any advice appreciated.
Zed
No, you have to RIP the vob files off the disk using a DVD RIPPER, preferably SMARTRIPPER, rip in BACKUP mode, then you can simply burn the folders made back onto the DVD-R...2 notes:
1) You will probably need to create a blank "Audio_ts" folder to burn on there as well.
2) As complete DVDs are sometimes bigger in size than 4.7 GB (typical DVD-R size) then you can see it will not fit. So sometimes YES, reencoding the movie to a slightly lower bitrate may be neccessary OR, the other trade off is losing some the DVD extras to conserve space.
<font size=-1>[ This Message was edited by: Kdiddy on 2001-10-23 15:59:53 ]</font>
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
DVD (VOB files) to avi
By hilario in forum DVD RippingReplies: 6Last Post: 30th Oct 2009, 10:44 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
How to join 2 DVD VOB files??
By hilario in forum EditingReplies: 5Last Post: 15th May 2007, 17:53
