Hi, I have backed up DVDs before using DVD shrink and Nero 6 so I know a little bit about DVD burning.
But now I have created some Quicktime Movies in Macromedia Flash and Director which I want to burn to DVD-R.
What format or program do I use to do this?
Do I convert the .MOV files to .VOB?
What is the standard format for burning to DVD?
What programs are the best for editing, converting and burning to DVD?
A couple more questions sorry.........
I converted my Quicktime Movie into .Mpeg
How do i burn it to DVD Nero 6 wont accept .Mpeg?
Also the .mpeg has lost the Quicktime Movies interactive features
Is there a way to burn to DVD but still keep the interactive features of Flash MX?
Thanks -
not that i know but (keeping interactive menus)
to be able to burn your mpg files to dvd with nero, you'll have to author them first...
there is a lot of programs that would help you with that
if you want the easy (but not the best) way simply use nero vission express
once you've authored your files, you'll be able to burn them to dvd with nero6Increase knowledge, increase sorrow. -
you cant keep the interactive menus
(not that i know at least)
dont know what its the best.. I use Scenarist (or trying to =)
take a look at the dvd authoring section
https://www.videohelp.com/tools?section=2#2
cheers
-stkIncrease knowledge, increase sorrow.
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 12:22 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 16:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
Mov To DVD
By dashali in forum Authoring (DVD)Replies: 1Last Post: 22nd Jan 2009, 05:56 -
MOV to DVD
By darogo in forum ffmpegX general discussionReplies: 9Last Post: 26th Apr 2008, 12:09
