I have a quick question for you guys, I hope someone can help me with this.
I have 2 avi files (XviD) with different bitrates. The two avi's are part of one movie and splitted into two files. I want to join them and convert them to DVDR.
Is this possible at all? I opened the files in GSpot and this are the results:
AVI 1:
XviD
01:34:59
576*320
Video 884 kbs
23,97 FPS
Audio 138 kbs (mp3)
AVI 2:
XviD
01:33:40
576*320
894 kbs
23,97 FPS
Audio 144 kbs (mp3)
I made a search in the guides and the forums but I couldnt find the usefull information. I hope anyone here can help me.
There's no need to join them. Convert them seperately then Author the resulting MPEG's.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Judging by the audio properties you posted, I believe you have a variable bitrate stream. You'll need to decompress the audio to wav and use the wav file as your audio source when converting to DVD mpeg. You may be planning to do this already but I thought I'd point it out just in case. Good luck.
I too have encountered this problem and by experiance I know its no problem to merge the two files together. I use VirtualDub to do it set video and audio to direct stream copy...
Here is my way....
Load 1st avi in Virtualdub set the video to direct stream copy and then the audio then click on file and append avi segment click on video again to make sure that direct stream copy is still selected and then save as avi
Voila about 2min later avi file merged....
Now you can work with it.....
Archie
I do this alot with no problems....Think Before You Do It -
One thing to note....I found as long as the video resolution is the same nothing else matters so both avi must be the same size in your case they are so no problems.... If they were differnt size then I would agree with the other guys and encode them seperately.
ArchieThink Before You Do It
xvid bitrates for restoration?
By timmus in forum RestorationReplies: 5Last Post: 14th Dec 2010, 05:51 -
Xvid VS X264 At High Bitrates
By mohawkcr in forum Video ConversionReplies: 1Last Post: 4th May 2010, 16:18 -
Dif / DV25 & Wav to MPEG (suitable for DVD burning)
By sevenleaf in forum Video ConversionReplies: 0Last Post: 21st Aug 2008, 04:33 -
bitrates for 650-700MB AVI to DVD
By ecc in forum Video ConversionReplies: 12Last Post: 20th Aug 2008, 18:26 -
Xvid to mpeg2 - bitrates
By 2nickelstripper in forum Video ConversionReplies: 10Last Post: 6th Dec 2007, 08:26
