Does anyone know why I can't convert wav to mp2 with ffmpeggui and headac3he-0.23a. When I use ffmpeggui, I can open the wave file, but when I click convert, the finished window immediately pops up. When I open the file it is 0kb. When I use headac3he-0.23a it says can't open source file. Can some one help me
Closed Thread
Originally Posted by james636
Try uninstalling and re-installing. It (ffmpeggui) really is a simple little app and so should work "off the shelf".
Failing that, Baldrick, the site Administartor, might know - he wrote the GUI for ffmpeg. Either contact him via the "Report all bugs here" link under the tool iteself (in the "Tools" section), PM him or maybe the "Feedback" forum.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
First off, Besweet doesn't even recognize the wav file. I used AVIcodec to tell if there was anything wrong with the wav file and it ststed that the file was supported and that I have the codec needed. But still I can not convert wav files to any other format. I can convert mp3 to mp2 and I can also play the wav file in WMP, but I can't convert. I tried uninstalling and reinstalling and that didn't work. Can someone help me
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10
