I have spent a lot of time capturing my dv and vhs tapes to my hard drive. I have been successfull at the capture, conversion and the authoring so far. I haven't needed to post on the forum yet, having learned from researching other's posts.
I am looking into buying a capture device/card like the canopus advc-100, but am not sold on the benefits yet. I am using just a generic firewire card right now that I connect my camcorder to, then I connect my camcorder to my vcr, but don't know if I'm missing out on something better in the firewire card area. So, here's my question:
How would a capture device like the canopus advc-100 or similar benefit my dv and vhs captureing above just going strait to my firewire card. Does it make the video clearer?
Also, I know that I need a firewire card to connect the canopus to my computer. Will just any cheap firewire card do, or would I benefit by buying a brand-name firewire card. The current firewire card hasn't malfunctioned, but I don't know if generic is the best, having not used any other firewire card.
Thanks for any advice any other users my have.
Daron
Closed Thread
I think you should leave well enough alone and stick with what you have. You don't even know how fortunate you are to have a DV cam with analog pass-through. Unless you want to be able to capture directly to mpeg-2, I don't see a single reason why you should get a capture card.
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 21:38 -
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 16:56 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 09:55 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
