I made a few homemovies in Mediastudio Pro and rendered them as SVCD MPG files.When I play the movies on the computer, they are fine. But after burning them to SVCD using DVD-Moviefactory, the sound is out of sync. The audio comes later than the video. Its only a few milliseconds, but its just enough to be noticable.....
Any ideas on where the problem might be coming from ????
I've had this same result and found that it was solved by saving the original movie first as AVI (big file), then burning the AVI to SVCD. Nero worked fine for me.
It could also be a problem with the type of discs you are using also.
Rendering to AVI is not an option, because I dont have that much diskspace. And whats with the disks ? Never heard of that before.
Sorry ignore, me talking bollocksOriginally Posted by Frandaman
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 16:03 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
