just wanted to let you guys know first that i done this before, so this error is pretty weird.
i have a .mkv file with two audio streams and 1 subtitle stream, i can play the .mkv file fine with windows media player classic but not with the normal windows media player, but that isnt my problem. I cant seem to demux the audio using virtualdubmod(this is my first time seeing this error), i think i have all the codecs installed because i can play the file with windows media player classic fine, but who knows. Also, i cant save the file to .ogm with virtualdubmod(i use to be able to do this), it says video problem or whatever. when i open the .mkv file with virtualdubmod i get an error at the bottom that says "Error decompressing video frame 0: An unknown error occurred...." anyone know how to fix this problem?
You sure you don't have the codec? Do you have a VFW CODEC? (Video for Windows, you need a DirectShow filter)...
open it in AVIcodec to be sure.
how to demux mkv file?
By shun in forum EditingReplies: 10Last Post: 24th Mar 2014, 07:31 -
demux avi, mkv file
By volam1 in forum EditingReplies: 19Last Post: 4th Oct 2013, 07:03 -
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 18:05 -
I have a .mpg file that I need to demux I want the audio..
By J Tinsby in forum Video ConversionReplies: 6Last Post: 23rd Jun 2011, 18:20 -
Cannot open file for audio demux output in DGindex
By andy_blah in forum DVD RippingReplies: 5Last Post: 31st Jan 2009, 16:53
