  1. Is it safe to say that if i want to convert an avi file of a bitrate of 1400 kbps to a SVCD file and i want to keed the exact same quality i should convert it with a bitrate of also 1400 kbps ?
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Absolutely not. There is virtualy no relation between Divx/Xvid and mpeg-2(or mpeg-1 or that matter) bitrates.
  3. So what bitrate should i select if i want to keep the same quality when converting AVI into SVCD ?
    Is there any rule ?
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    1. Don't put more than 45 minutes on a single SVCD
    2. Use a bitrate calculator such as this one.
