I am using Sonic MyDVD that came with my DVD burner. I use it with my Adaptec capture card to transfer home VHS to DVD. Then one day MyDVD gets an runtime error! I checked the Sonic website and seems that others have the same problem. I have the latest version of MyDVD which Sonic claims to solve the runtime error. But still got the error! I don't get the splash screen.
I un-installed the latest version and re-installed the version that came with my DVD. However now I get an Invalid Pointer error message when I click on the capture icon.
I tried to use Ulead Video Studio 5 that came with my firewire card but it does not detect the adaptec capture card.
Any help is appreciated.
Thanks.
Originally Posted by copiador
I suggest you ditch both (Ver. 5???) and get yourself a decent authoring/capping app and a good editing app. Search around here and you'll get plenty of ideas for apps that are free, inexpensive and very expensive ....all of which work better than the two you're struggling with. VS5 is 2 years old, is buggy as hell, and is slower than the second-coming
MyDVD is so badly coded that it isn't worth the plastic of the CD it came on, assuming it didn't come on floppies
Good luck
Which software do you suggest? I tried both Ulead and Adobe Premiere 6 but neither will work with my Adaptec capture card
Put some feelers out in the DVD Authoring and the DVD Capturing topics here and you'll get lots of feedback as everybody thinks they've got the best combination of software ....and if they're happy, they're right -
Believe or not but my adaptec card came with MyDVD
I use MyDVD only to capture home VHS. I use TMPGENc and TMPGEnc DVD Authoring to edit and create menus. So far I tested Ulead Video Studio 5 and Adobe Premiere 6 (which does not support adaptec card). I contacted Adaptec and they said that the card works only with the bundled software. I guess that I need to spend time and hunt for a software that works with adaptec card. -
That would probably be the most stress-free route
Good luck to you
My Unlocked Phillips dvp3980 has suddenly stopped playing AVI files?
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 11:58 -
Svcd2dvd stopped working
By H4MST3R in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 12th Apr 2011, 21:53 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 07:07 -
Power2go suddenly stopped working properly
By DaneClark in forum Authoring (DVD)Replies: 0Last Post: 7th May 2010, 17:06 -
EZ Takes DVD suddenly stopped working?
By greenr18 in forum Software PlayingReplies: 1Last Post: 13th Nov 2007, 12:17
