  1. Hi All
    I have downloaded and installed all componants of this program, all went well and everything installed OK.
    My problem is this.
    I select an .mpg file to Encode, I setup ffmpegx to convert to MPEG4 [.avi] (mencoder)
    I select the output file, and then click on Encode, the process window opens and after a very short time, it dings at me and states that it is finished.
    There is no output file, if I then click on the (i) Info button the window opens, but it ois empty, no Info.
    I am at a loss as to what could be doing wrong, I have even read the Information on the ffmpegx website, and can not see what I could not be doing to get this to work.
    Chris
  2. Guest
    I just decided I would try reinstalling the main prpgram, all is OK now, sorry to be a pest.
    Just one other thing while I am here, what is DD2 as I have been guided to this to convert .avi files to .mov files and then join them?
    Chris
  3. All sorted now.
    Just me trying to run before I could walk, so to speak.
  4. I've had the same problem-- everything appears to work fine but no output. I tried reloading the program and no luck. the info gives me a message about not finding a "sequence header" (see below). any suggestions? thanks!
    Encoding started on Mon Apr 19 09:41:23 PDT 2004
    Using GNU internationalization
    Original domain: messages
    Original dirname: /sw/share/locale
    Current domain: mplayer
    Current dirname: /usr/local/share/locale
    MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    AltiVec found
    Reading /Users/kirkevans/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
    File not found: 'frameno.avi'
    success: format: 0 data: 0x0 - 0x12800
    MPEG-ES file format detected.
    MPEG: FATAL: EOF while searching for sequence header.
    Video: Cannot read properties.
    Exiting...
