Hallo everybody,
I want ask, if is posible capture video from my SONY DCR-TRV320E directly to Adobe Premiere (Ulead DVD Workshop,Ulead Media Studio, PinacleSdudio, ...) without using FastForward software ...???
Because, when I try by this way, it's not working (device control for camera is not working) ...
Thanks a lot for![]()
What is FastForward software?? I use Mediastudio Pro to capture and it just does it. You do have to set the Device Control though. It defaults to None but I need to set it to MS 1394.
Hi sovcik,
I use Adobe Premiere 6.0 and can capture from my DV cam without using other software.I want ask, if is posible capture video from my SONY DCR-TRV320E directly to Adobe Premiere
I'm not at my usual PC, so can't remember the exact steps - but you can set Premiere to recognise your DV cam (there's loads in a list, or you can do "generic" settings).
Post back how you get on. If need be, I can post the steps and screensprints for you.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
HD Camera capture software
By tarzan54 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 5th Feb 2012, 11:59 -
Capture from camera-no sound
By Mållgan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2011, 11:43 -
Capture from PC to Video Camera
By gamerscircle in forum Newbie / General discussionsReplies: 14Last Post: 4th Jan 2009, 13:21 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 15:13 -
What's the best software to capture a still Photograph from a DV Camera?
By Mark97213 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Jul 2008, 18:54
