I'm toying with using SVCD2DVD to create DVDs from my VCD / SVCD sources, however my standalone player does NOT play VCD of SVCD format: can this tool create DVDs that I can play on my standalone player? Thanks in advance.
To get a simple yes or no answer you'll need to call the psychic hotline. Not all DVD players are created equal. The only way to find out for sure is by trying it yourself. Good luck, and post your results.
There are samples to download & burn to test your player on the site....so maybe!
Newbie that needs answer to a question: Transferring videos to a Mac?
By PlatS in forum Newbie / General discussionsReplies: 11Last Post: 10th Nov 2010, 23:28 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 11:49 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34
