I reinstalled TMPGenc
and now if i want to convert a avi file to a svcd file
i can't adjust the bitrate at the end of the wizard
it is always stuck at 1600.
Who can i change the bitrate setting like i was able to do before ?
Results 1 to 11 of 11
Ok i try this one
but if i change this option (that is by default at 1600)
to let's say 1200
as soon as i change to another option or i click ok
the option goes back to 1600 and I don't know why -
Change the encode method from CQ to VBR.
Cheers, Jim
My DVDLab Guides -
If you try and set it to 1200, then don't bother. I wouldn't reccomend anything lower than 1600, and actually prefer 2000+. Do a test encoded to see what the quality is.....
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
bambam: Are you using the video file as both the video AND audio? I don't know if it's a bug or what, but if I had an avi, say video with .wav in it, tmpg wouldn't let me drop to a certain disc % no matter what if I had it have a/v as the same file. Once I extracted the wav and just used it separately I was able to keep whatever bitrate I wanted.
I usually use the same source for audio and video
I only split the audio and video when the first method don't work...
Can you change the video bitrate with Multiavchd?
By jbitakis in forum Authoring (Blu-ray)Replies: 0Last Post: 28th Nov 2011, 00:57 -
mkvmerge Videosize/Bitrate change after merge?
By ck0 in forum EditingReplies: 6Last Post: 8th Sep 2010, 06:57 -
How do I change an .H264 TS video file's bitrate?
By bubbrubb in forum Video ConversionReplies: 1Last Post: 15th Feb 2010, 13:47 -
change audio bitrate in ConvertXtoDVD
By ecc in forum Video ConversionReplies: 9Last Post: 16th Nov 2008, 21:15 -
change video bitrate
By Ogilvy in forum EditingReplies: 2Last Post: 3rd Jul 2008, 13:07
