Lately i downloaded a avi movie files, which i think comes with dts sound, with that, i cant convert the whole avi to mpg.
Using avicodec, i arrived at this
File : 702 Mb (700 Mb), duration 0:41:50, type AVI, 1 audio stream(s), quality 86 %
Video : 474 Mb, 1586 Kbps, 23.976 fps, res. 640*352 (16:9), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported
Audio : 225 Mb, 754 Kbps, 48000 Hz, 5 chan., 0x2001 = Unknown, Unsupported.
I dont know what the format of the sound is in, but i suspect its should be in dts as the file name end with this 'DivX.dts-K2.avi'
If you don't have any sound when you play the avi, you need an ac-3 filter. Use Goldwave to create a wav file of the avi's audio. Use the wav file as your audio source when converting to mpeg. If you want to maintain the ac-3 sound in your mpeg that's going to require more work.
Hypercube transcoder may work
Thank, but still cannot, i am able to open the file, but when it encodes, it goes over the 200%mark and still would not stop, so i had to stop it manually, than when i open the mp2, the sound is kinda like auto repeated itself, like having only 1s of audio and repeated for 136min!!!Originally Posted by BJ_M
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 09:23 -
Convert DTS 23.97 to 25 ??
By Summersun78 in forum AudioReplies: 1Last Post: 14th Nov 2009, 04:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
