Hi,
been reading through the site for some time, basically i have a number of files in various different formats, xvid, divx etc etc.
Is there any program that will take this file and burn it onto dvd without me having to mess around with multiplexing, converting etc. etc.
obviously i want my dvd to be compatible with a stand alone dvd player.
im willing to spend £800
Also i understand that i may have to use a seperate program to burn the dvds this is ok, but which program should i get? i tried nero but it only supports miniDVD not actual DVD![]()
Nero is your best bet as far as ease of use goes. Quality won't be the greatest but that's to be expected when you allow a single program to do all of the work for you. After starting Nero you should see the new compilation window. Do you have a drop box in the upper left corner that you can change to DVD? If not, this might be because you presently have a cd-rw drive selected as your recorder instead of your DVD burner. Or maybe you just have an old version. You might want to do a little more tinkering with Nero before you blow your money on something you may not even need.
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 13:35 -
HELP - no sound from avi's and mpegs
By mstumpf123 in forum AudioReplies: 3Last Post: 17th Jun 2009, 22:52 -
it even happens to rocket sientists - the space station is infested
By minidv2dvd in forum ComputerReplies: 1Last Post: 5th Sep 2008, 23:54 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 16:06 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 21:29
