Is there anyway to make Canopus Pro Coder read vob files?
Or what about AVID XPress 3.5?
Regards
Peter
Results 1 to 10 of 10
It officially does not do that,
But with the following register addon it does!
Here's the value that needs to be added:
l
HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\ProcoderContro l
Add the new dword value:
ImportVOB = 1
Works great! -
Just to explain a bit more,
To create a reg file to enable VOB's import in procoder, do this:
Open a Text editor
Paste the following text:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\ProcoderContro l]
"ImportVOB"=dword:00000001
Save this to a file named procoderVob.reg
Then you can double click the file to add the register patch. -
Hey Doman, you wouldn't happen to know how to make Vegas Video import M2V files would ya?
Well that worked really well for the video so thanks a lot.
However the audio file exported had no sound, does it not do sound or am I doing something wrong?
Peter -
Ok, I just tried to convert 2 VOB files one with MPG2 audio and the other with AC3 audio.
The audio in the resulting files seems to be ok.
I normally don't use procoder to import VOB files.
Get a pop up asking if I want to use ffdshow in Pro Coder ( what is it ? )
By beammeup in forum Video ConversionReplies: 1Last Post: 23rd Feb 2012, 03:37 -
Problem capturing with canopus mpeg pro emr...
By dhugg in forum Capturing and VCRReplies: 4Last Post: 5th Jun 2010, 15:43 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 20:18 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 05:15
will give it a go. thanks
