  1. i looking to burn a film down to svcd format......
    obviously it wont fit on 1 cd....So.....can someone help , how you convert using DVD2SVCD .And also how do you split the file to convert the 2 separate parts onto 2 cds
    thanks
  2. Do a forum search, your question has been asked many times before.
    If it's wet, drink it
    My DVD Collection
  3. Im gonna do this even if it kills me !!!!!!!!!
    im following this guide :
    https://www.videohelp.com/forum/userguides/111846.php
    Im using virtualdub to split my movie in two parts....Now , the movie is fine before the split ......Proir to burning, when i come to check the 2 split parts in my media player on my pc i discover problems.....varying from :
    -slow motion sections( which knocks the audio out of sync temporarily )
    -1st split part fine but 2nd is way out of sync....
    I know the movie is fine because ive converted as much as i can fit onto a cd ( svcd format )and played in my dvd player....Im just having a big problem when i cut a movie....
    I CAN do all the dvd2svcd & TMPGEnc stuff no problem if i was just doing one cd.........it all seems to go wrong as soon as i split movie into two parts....
    Im very new to this and would really appreciate someone telling me where im going wrong...
    please...
