I am using the Pioneer DVDRW 105 and have tried to use the Generic-mmc driver to burn to VCD not DVD but it does not work, I am also using VCDeasy V1.6, do I need a newer version or I am I doing something else wrong
Hi!
What happends? Any error message? If you can't burn directly from VCDEasy, then I suggest you try burn a Image-file and the use Nero to burn your image to the CD.
// Znooky
It says that it cant activate the drive and to try and change the force driver which I have done on a number of occaisions, I have also tried to burn the bin/cue file using nero which tells me to overburn so have set it up to do that and it cant write disc at once after that I have even tried using bigger CDs and nero wont entertain them either even when I change to settings to 90 min CDs
Older versions have this problem. I remember that in 1.1.7.2 with Pioneer A06, I had to change the driver each time, but I was able to burn at the end. The latest 2.0 supports SPTI in WinXP and works without hassle. In any case, you can use BAO (freeware) to burn the image.
www.burnatonce.com
moggy1917 -- what aspi layer do you have? i have the pioneer 105, aspi 4.6.0 (adaptec force aspi layer), using the generic mmc driver, and an older free version of vcd easy (can't recall the exact version, though i think it is 1.1.7.2) running on a sony vaio desktop with XP. check here . i think i had to do the force aspi to burn with vcdeasy's engine since i did not have nero at the time. the alternative, as others suggested, was to create an image with vcd easy and burn with nero (also described in the above link).
HELP PLEEEEEEZE! Pioneer DVR 111L Writer, Need Driver
By golfnut in forum DVD & Blu-ray WritersReplies: 6Last Post: 18th Feb 2010, 22:09 -
driver help
By romanstopme in forum ComputerReplies: 1Last Post: 19th Nov 2009, 00:30 -
driver help
By Mr anderson in forum ComputerReplies: 9Last Post: 11th Jul 2008, 14:51 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23 -
Pioneer dvd-rw dvr-112D Driver Update
By scustalow in forum DVD RippingReplies: 1Last Post: 27th Jul 2007, 14:16
